Hi all, any advice please for removing or concealing a scuff on the dash. This is the soft touch plastic, with a matt finish, and this has polished up. Looks worse in the pic than in reality, have to catch the right angle and light to see it. I wiped over the whole dash area with Dr Leather on a micro fibre cloth. No other marks from doing this, so either it was already there, or there was a small particle on the dash that got pulled across it. Thanks
I would suggest trying "303 Aerospace Protectant" spray.
I've had good results with Adams Interior Detailer
Initially I’d wipe it with a damp cloth and let it dry just to establish that the mark is on the dash material and not ‘within’ a previous surface product finish.
If it is ‘in’ the dashboard plastic (which seems most likely but you may be lucky!) I’d say pretty much any matt finish plastic / rubber product. My personal favourite is Poorboys rubber and plastic but there are loads that do much the same job.
Good luck!
Try using a steamer as this softens the leather I use it on leather seats and works pretty well and it tightens it all up.
46 minutes ago, Al D-Much said:
That dash is leather, not plastic.
I think you are mistaken...it is almost certainly a man made material,albeit with a leather look-alike grain.I would suspect the nearest it has been to a cow is the last time it went past a MacDonalds.
  • Haha 3
Nearly Fell Of My Chair Laughing at That One David..!!!!!!!!!!!!!!!!!!
.......but was it a leather chair or plastic?
  • Haha 2
