Has anyone thought about this?  I have made some enquiries,. but the price for all required items is far too excessive.
Will rely on lexus breakdown should we be unfortunate enough to suffer a puncture.
Care to share the cost ?
Remembering that RAC cover can often utilise the Spacesaver wheels which the RAC van holds ( if he has any left on board ) which you go to the tyre garage with and they hold that Spacesaver for return/ collection by the RAC itself
Assuming the RAC guy has any remaining on board at that time
It’s not just a puncture it’s a pothole tyre write-off these days one has to be wary of
I don’t know if the Lexus Breakdown you hold covers all this !
Good luck
yes the cost will be approx £2000.
There is no space for spare wheel.
Raise the floor, all new panels. wheel and tyre,  jack, wheel brace, wheel nut spanner, spare wheel bolt.
  • Sad 4
That's just ridiculous !!! Are the tyres run flats as standard or is it a can of gunk and a compressor ?
This thread prompted me to check with my dealer today……
1. There is a puncture repair kit supplier with the car.
2. The tyres are not run flats.
3. No spare no space saver either.
I hope this helps……also not an unusual position for a modern car……
I don't know how you get to £2000.
I bought a space saver for my RC last year for about £270.It sits on  my boot floor and doesn't slide around.It still leaves ample space for luggage or shopping.And,no,the RC doesn't have a large boot.Was your spare gold or some exotic material?
I assume it’s for all these bits… “Raise the floor, all new panels. wheel and tyre,  jack, wheel brace, wheel nut spanner, spare wheel bolt.”
someone in the parts department was taking the p*ss.
The Recovery Breakdown people will have the jack, wheel brace etc so you won't need to buy and store those ....
It depends.  If there is an option for an underfloor spacesaver and to do it properly it requires the side panels to be charged, then there’s quite a lot of work involved and with the parts, £2k isn’t unreasonable.   However, if you’re happy with it just placed under the existing floor it could be done a lot cheaper.
  • 6 months later...
This is my solution to the LBX Spacesaver problem. Photos attached. It raises the boot floor by 60mm. Boot floor is perfectly flat and rigid. Cost about £220, including new 18” spacesaver, fixing bolt and tools.
  • Like 6
For 2WD version ok, but for 4WD it is probably not acceptable for most users.
Hi Dave,
who and where did you get this spacesaver done for £270, this could be a lucrative enterprise for them especially on here with a captive audience.
Agreed, the 4WD cannot accommodate a spare wheel.
1 hour ago, Natman01 said:
Hi Dave,
Hi Nathaniel,
I did it myself. I bought the new 18” space saver spare wheel and tools off eBay for £189.95. The fixing bolt from eBay for £12.95. I made the wooden top for the rim from 15mm plywood, costing £8. I made the front, back and side supports from a 60mm x 1200mm x 450mm Celotex Insulation board, which I already had, but it costs about £14 for a board.
The foam filling in the Celotex board is quite strong, lightweight and supports the boot floor very well. Maybe I should patent the idea, but it could be quite lucrative for a professional company if they are able to  produce the supports in a suitable, lightweight, material.
My mate carries a spacesaver in a bag on the boot floor.
Could you please send us the link or specification of the spare wheel and eqiuipment?
I did not found any wrench for wheel bolts in my LBX, only this standard flat tire emergency equipment. However, my dealer included a special key socket for anti-theft bolts they installed for free – but not very consistent.  Today, I do not consider buying a wrench, lift and spare wheel having Lexus support within warranty period, but leter probably I do.  (BTW: my previous car was Subaru Forester XT  2016 which had pare wheel included, and earlier XT 2009 which had full size wheel!)
15 hours ago, Dasalias said:
Hi Nathaniel,
Well done very ingenious of yourself, thank you for your info and yes perhaps you should go on Dragons Den to pitch your idea.
This is the eBay link to the 18” LBX Space Saver Spare Wheel:
www.ebay.co.uk/itm/166779865097
Thank you. Now, I wonder where is a place in the LBX designated to support the lift?
Hi there - I'm thinking of buying the same for my IS300h - the quality looks decent.
I was wondering how it get delivered ? Just in a box ?
Is the fixing for the central wheel bolt already present out of interest ?
The spare wheel and tools are delivered in a box.
In the LBX, the fixing bolt does not come with the car and is not included with the spare wheel. It has to be purchased separately. The fixing bolt needs to have a screw length of at least 130mm from the underside of the knob. The screw thread is 8mm.
