MBJ
Does anyone know where to get replacement wing mirror glass for a 2017 IS300H other than from Lexus direct and does anyone know if it’s the same size and fit as previous IS300H models or any other IS models such as the 200 or 250?
Any help would be greatly appreciated.
Thank you.
Hi Matt and welcome to the LOC.
Amayama are listing at just under £200.00 shipped other than that it’s finding a good used one from a write off and I think they are model specific.
Thanks Steve2006.
Lexus Parts Direct have them too at around £126 for the drivers side replacement glass.
I've found passenger side glass for £30 but not for drivers side yet. A bit of a difference in price for a simple part.
Matt hi ……. nothing as simple as it maybe should be with mirror glass …….. many posts over the years for various models with some members making do with glass that’s not quite right often due to the huge cost of replacement ……. some slightly concave / convex , dimming and maybe slight vertical lines in the glass for reversing focussing whatever ……. The prices for new can be huge and £200 might be a steal tbh
£30 seems brilliant if it really is the correct part
There are a few independent glass mirror producers that cut to a template if not available in stock BUT they might not be “ quite right “ but suffice for some 🤔
it’s a potential minefield !
Good luck
Hi Malc,
Thanks so much for the insight. I’m quickly getting a feel for it and it seems that drivers side glass is at a premium. I’ll investigate further and try to find out if in fact previous IS300 or any other IS models for that matter might be similar in size.
The key will be the backing plate and if it’s heated or not.
Thanks again,
Matt
