Temperature control button is stuck
My temperature button to lower the temperature is stuck which has dropped the desired temperature to 60 degrees. Therefore the button to increase the temperature does not respond. Does anyone have any simple solutions before I take it to a Lexus dealer?
thank you
BES
5 minutes ago, Spock66 said:
Switch cleaner spray?
Yes my thoughts as well, spray down the sides then tap-tap and hope it pops out
