Hello guys,
“I noticed” this loud noise from the trunk arms when closing / opening it, do you have any suggestions to solve it?
I heard Lexus changed 3 times the supplier of the arms for some recalls until the v3 seems to work.
Anyone that has passed from this experience or recall?
Let me know thanks!
Hello guys,
Anyone that may help?
Do you think some silicon grease or silicon oil will make the job for these trunk arms?
Let me know your opinion, thanks! 🙏
I  would certainly give it a try.
Once a year, when I wipe over all the rubber trim with Gummi Pfledge, I also lubricate all the hinges and boot struts. If I recall, I use either Fluid Film or SuperLube, and either spray a little into the crevices, or wipe it on with a cloth.
For the record, I also give the underside an annual spray of ACF-50, which not protects against corrosion, but also helps to keep things lubricated. As a result I have no creaks or squeaks.
18 hours ago, andrew-amazing said:
Hello guys,
Yes Silicone spray, works every time.
9 hours ago, RONNIE W HODGEKINSON said:
Where do you buy this silicone Spray Neil..?
B&Q, Screwfix.
I solved the issue with some simple WD-40!
To maintain the effectiveness of lubrication over the long term, I purchased this SIlicone Lube, perfectly compatible with the trunk lift struts materials 🙂
2'500 EUR avoided from dealership!
  • 4 months later...
Hi guys, tha car has been at the Lexus dealership and they have changed the electric struts on the tailgate and fixed the rivets inside the tailgate. Now all good!
Apparently this is a common problem and very expensive to fix out of warranty.
