The tailgate works fine on the remote, but won't manually open using the latch button.
When opening and closing on the remote, I can't hear the tailgate lock operating.
Before I start removing the tailgate panel to check, is there anything others have come across that may be the problem.
Thanks in advance
see here:
I suspect the rubber has split and allowed water in the switch. Unless you can dry it out I suspect you will need a replacement switch, not just the rubber.
Thanks for the prompt reply.
I'll check it out in the morning, and see if this is the issue.
Best regards
  • 2 months later...
Best regards
Hi mate, did you resolve this? I'm having the same issue, the boot won't open only when using the manual button. The key fob and interior button work fine
I bought this item number 393691189056 from eBay
I was a bit dubious with an aftermarket part, but it fitted and worked a treat.
I dread to think what the OEM price is.
Takes about 30 mins to fit.
Remove the back panel, there a 4 x 10mm nuts holding the lock assembly/number plate light unit, you can get to them quite easily through the gaps in the rear door
30 minutes ago, Ridgeback said:
I bought this item number 393691189056 from Ebay
Many thanks, will try this
