HI,
My car cut out, started again ok and drives fine.
It came up with Check VSC message and a few lights, are there any common issues to check and an order of what to check first ie easiest!
Nick
Hi
The most accurate way to check the cause is plug in a code reader  - this will give you a fualt code and description of fault.
There is more than one reason for this e.g loose petrol cap or O2 sensor
hope this helps
Hi Nick. It is recommended that you get Techstream. This is the Only diagnostic program that works 100% with your car. Other generic ones only work at best 70ish%.
What you could do for now is disconnect the Battery and leave disconnected for 30-45 minutes. This usually clears codes But if they appear again Techstream will tell you exactly what the problem is and what needs to be replaced.
One thing I suggest, and to all is250 owners, is to take the multiplug off the ABS unit and check the condition of the pins of the plug and the sockets of the ABS unit. I unfortunately found water ingress and rust in the sockets which meant the ABS unit had to be replaced. Scarey yes but it happened to my car and that had a Full Dealer service history.
  • 1 month later...
since i have just cleared the fault code P0093, major fuel leak, i havent had an issue.
will check the ABS unit
