Can anyone recommend a Stanley knife-type blade which does not go blunt after 2 minutes' use?
Doesn't exist..
I watched when our carpet was fitted and the guys put new blades in every 6 cuts or so. Well they had the snap off to renew type.
No blade keeps it's edge in use, just depends what you are cutting as to how quickly it blunts.
5 hours ago, NemesisUK said:
Doesn't exist..
The knife is for general DIY use. Years ago these blades used to last a lot longer.
As said, the "proper Stanley blades" last a bit longer.
300 year old Katana - still sharp!
mother-in-laws tongue comes to mind ...........
  • Haha 3
She'll be about as old as that Katana blade won't she?
  • Haha 2
On 1/21/2024 at 12:38 PM, ColinBarber said:
These definitely last longer than the standard cheap blades:
https://www.screwfix.com/p/stanley-fatmax-2-11-800-carbide-straight-knife-blades-10-pack/671jw
I would also get a diamond stone - Stone - I use one of these to keep the blades sharp for a long time as even the fatmx will blunt.  Means less time swapping blades and good for the planet as not sending all those blades to landfill.
Pete.
Thank you. I have ordered one.
