600h 2011 headlight lens covers
Hi all.
After a run in with the eternal enemy (a pigeon) I now have a cracked headlight cover. No damage underneath but lexus are out of the part until 3rd of Jan (£300!), and MOT is due the end of this month.
eBay isn't turning any covers up that I can see for the 2010/1/2 years with the 4 bar grill, does anyone have any ideas? A whole unit is probably more attainable I guess but costs several times more.
think the part no. is 81171B (lh) - lexus wouldn't give me the code. Chassis no. Is uv45-5012032 - it's a JDM. Is it the same part as same years 460s?
If it’s just a thick plastic lens can’t it simply be “ fixed “ with goo/ glue ?
Ask an MOT Tester if that’s ok maybe
I remember years past with glass headlamps that used to be an MOT acceptable fix
For the 07 model the part numbers are the same for the headlights (81185-50360, left headlight for RHD cars) for both the 460 and 600 so it looks like you should be able to use the lens from a 460.
https://lexus-europe.epc-data.com/ls460_460l/usf40r/5113/electric/8101/81175/
https://lexus-europe.epc-data.com/ls600h_600hl/uvf45r/5121/electric/8101/81175/
