Can anyone please advise towing limit for a 2021/2022 RX450h. It seems to vary between 3500lbs/1600kg to 2000kg, depending what I read
In the UK it's always been 2000kg for a braked trailer on the RX but have seen a 1500kg for some other countries. The difference is probably due to local laws rather than any difference in the car itself.
Would this not be on the data label on the driver's door shut? Gross Train Weight - Unladen Weight?
Also listed in the owner's handbook in the Specification section.
Its the same chassis as my 2017 version so its 2000kg.
That said, ive towed 2000kg TA caravans with much more powerful BMW X5's and wouldn't really fancy that load on the RX.
She tows 1500kg single axle quite nicely though.
