Hi all, I have a climate schedule on the phone, front and rear demisters, heated steering wheel, and seats all come on, but no cabin heat is supplied until I start the car. Any ideas? Played around with the temperature settings, but no difference.
I think that is how it is designed to work, mine does the same. I read somewhere that heating the seat and steering wheel was the most efficient way of keeping the driver warm and comfortable; saves the energy of heating a big empty space.
Switching the front demist on causes the engine to start to improve how quickly warmed air is supplied to the windscreen
Thanks for that, will be interesting to see if that will be enough to deice the side windows…
With a heavy frost, a 20 minute cycle defrosts the front door windows but not the rear door windows.
My 350h now stops the pre heat after 10 minutes - used to run for 20.  This is when it decides it wants to run.
Interestingly, whilst it may warm the car up it usually steams the windows as if the a/c is off.
