My UX F Sport was new in June 2020 and has been serviced every June. It has now done 19,750 miles. When you first start it the mileometer says xx miles to a service. Then changes to total mileage covered. Today it said ‘service engine oil soon’
This can be removed and the display returned to normal by pressing the return button on the left side of the steering wheel. But this message returns every time you restart the car and has to be turned back to normal using the return button.
I assume that the service technician resets this after a service as it didn’t happen last year or the year before. It seems it wasn’t reset after the service in June this year.
There’s no mention in the handbook of how to reset it. Can only the main dealer reset it?
Does anyone know or has anyone experienced this and knows how to reset it?
11 minutes ago, Don C said:
I think David is doing this already Don.
Don’t think so Barry, he’s just clearing the message by pressing return as I read it.
Doesn't surprise me David when you have had it in for service they have not reset it. Last time i had mine in first morning i drove mine was on way to Cornwall early hours and windscreen was misting up, they had knocked the air con or mucked about with the climate concierge and not put it back i had to stop park up to inspect and put back. The vid Don has posted will sort you out well done Don.
Thank you Don C and Navnan 2 for the video and comments. You are correct, I was only pressing the return button. I’ll try the instructions in the video. Thanks once again.
