Clutch Replacement
Rugbybarrel
I have a slipping clutch and am getting some quite expensive quotes back for changing the clutch, i have a 2007 is 220d.
They are saying that along with the clutch i will need to change the flywheel which is dual mass, so this makes the quote even higher, does this actually need to be done??
Quotes are around £750 for the clutch, when you add the flywheel they go up to  around £1,500.
The car is quite old being a 2007 so if going up to £1,500 probably not worth doing!
Any advice around if the flywheel needs replacing and any idea of costs would be useful.
Nick
I believe it's best practice with a dual mass flywheel to have it replaced, you could try getting some quotes from here.
https://bookmygarage.com/blog/clutch-replacement/#toc-heading-3
Hi Nick,
As Andrew says, it is best practice to change the dual mass flywheel whilst doing the clutch.
However, it might not be necessary.  If you aren't experiencing any juddering when engaging the clutch, then it is probably ok for now, but since your car is quite old, it is most likely quite worn so who knows how much longer it will last?
When I had my IS220d, it was the other way around:  I need a flywheel, so replaced the clutch at the same time since it was out anyway.
I appreciate this isn't the same thing since the flywheel is substantially more expensive than a clutch, but the theory is the same.
So it is down to you whether you want to take the risk.  If you aren't willing the spend the money changing the flywheel because the car is so old, then your choices are somewhat limited I'm afraid.
  • 6 months later...
On 11/13/2023 at 2:04 PM, HPS13 said:
Have any owners done a conversion from a dual mass to a single mass flywheel?
Yes, I was having a conversation with a guy in America who went for the Fidanza SMF and it's not very good. There's a lot chatter and it just doesn't work very well on this car. When I had my first clutch changed at 140k miles, the flywheel was still fine to re-use. Garages tend to squeeze you for it and say you need a flywheel when you don't.
