Hi all,
I have checked that the sunroof drain holes both front and rear are properly draining water as they should, so do not believe that this is the cause of water ingress into the rear footwells. Does anybody know if there are other possible common causes for this to happen?
Have a look through this thread, and the others that get mentioned in it. Roof bars, rear light seals, body joints that are glued are all sources of water ingress as these vehicles age.
