Gentlemen want to figure out what to do with the breather valve on the top of the rocker cover as it no longer goes to the stock air box as the car is supercharged and really don't want to leave it open  any suggestions 🤝
The best way to handle crankcase fumes is to run a hose from the rocker cover vent to a closed catch can. Then run a second hose taking the cleaned fumes from the catch can to a connection on your inlet duct after the air filter and before the throttle plate.
Cheers...
