Hello New Members Area,
I have just joined this forum and wanted to ask if anyone can access the correct headlamps for the above vehicle?
Toyota don't make them anymore and it's very difficult to find them here and there can be a risk when purchasing from abroad that you receive headlamps for a LHD car which cannot be used here!
I have been told that the original part numbers are: 81130-6A111 (right) and 81170-60831 (left).
If anyone knows where they can be actually found in the UK or reliably sourced from abroad I would be very grateful.
Many thanks in hope...
Geoff welcome  .....  were you able to make any headway with this ?
Hello Geoffrey and welcome to the best Lexus forum there is.
Why do you need replacement headlights? Usually headlight faults are bulbs or the lenses have become dull or damaged. Which is your issue?
Many thanks for all your replies, particularly NemesisUK, and I have submitted an enquiry to Amayama.com and am hoping they can help...
Just out of interest, does anyone know if left hand drive headlamps can be legally adjusted to dip in the correct direction so as to comply with the UK MOT?
I understand they cannot as it is to do with the moulding of the lens but worth a question as they are brand new.
I need replacement headlamps as they were damaged by an argument with a wall!
The other company I have contacted about this is Nippon Auto Spares Ltd, nipponautospares.com, who are going to see if they can access them from Japan.
Thanks again and much appreciated.
Just to update - I have found replacement RHD Halo headlights on eBay which are from Taiwan.
Thanks again for all your help with this and hopefully I should be able to get the car back on the road soon!
