On 7/13/2024 at 12:25 PM, RONNIE W HODGEKINSON said:
Exactly Colin Mine does The same..!!!!
Ronnie....have you experienced any 12v Battery issues since you installed the DB2?
2 hours ago, Hayzee said:
Ronnie....have you experienced any 12v battery issues since you installed the DB2?
None Whatsoever Colin.. I Check the 12v Battery Reading daily and it Never drops below 12v...This little gadget is the best purchase i have made in a LONG time.. I Think Problems arise with the Battery when dashcams or other ancillary equipment are installed which can put a slight drain on the system....I,m sure the DB2 has a Sleep Circuit built in which does not draw any power when the Car is not in use....Regards.!!!
