Hi people my sc430 is making a rubbing sound from the rear wheels or that area mainly when going round bends , on a left bend it’s the right hand rear and on a right bend it’s the left hand rear , you hear it more with the top down  it’s not really noisy it’s just annoying when your out for a quiet and leisurely drive.
I am mechanical minded maybe this has come up before it’s the first time of owning an sc430  what a beautiful car, thanks in advance.
chris
Chris.
If you slow down on a bend without braking does the rubbing noise slow down as well?
Hi Richard , I will need to check again and let you know  , so like speed related, I will try tomorrow, 👍
Hi guys I am thinking it’s the hand brake shoes making this noise, I will be stripping them down sone.
Chris.
I was thinking parking brake shoes or sticking caliper(s). Before you strip everything down check for a stone lodged between the disc and caliper or pads, particularly if you have driven over a resurfaced road recently. Let us know how you get on.
chris
The back plate for the handbrake shoes are common for rubbing on the back of the brake disc.(it’s an age/ wear thing)
Remove Caliper and disc, grind/file away the lip at the bottom of the backplate..it will be shiny where it’s been rubbing .
  • 4 months later...
My backplates around the discs have been removed/rotted/fell off but I get that rubbing sound going round bends.🤷🏻‍♂️🤷🏻‍♂️
The rubbing sound is the handbrake shoes back plate rubbing on the back of the disc.
The disc could be very corroded causing it to rub, but I suspect it’s the backplate distorted due to age.
I've ground a small amount of metal off the lip,on the back plate on two SC430’s and a IS300 with good results afterwards.
see lip next to handbrake shoes, rubs around at the bottom.
Hi Bob  you are spot on ,the rear brake discs are nearly new condition , after stripping them down
and looking very closely I noticed a shiner area on the bottom of the ridge  , it was hard to see I spotted it only when I got my torch on it .
so I used my hand grinder to grind a small amount of metal away from the edge
fitted everything back together took it out for a test drive the car is now perfect.
I am thinking the rear brake disc being after market maybe the clearance between the
disc and the back plate is is not enough.
