If you can weld, fabricate and happy to chop, cut and modify your rear valance I would say yes.
If you’re looking at plug and play no.
I remember years ago a local guy nicknamed Cooter would make you an exhaust system from the scrap he collected from exhaust fitting centres, they were aptly named “Cooter exhausts” 😀
2 hours ago, ISF V8 JAY said:
Silly question!!
can I fit an RCF Exhaust (Back boxes) on a 2009 IS250?
TIA!!
Any exhaust place can adapt it to fit.
But no... Not without modification.
Then as well consider you need to cut the bumper quite a lot.
Even if you can make it fit, I'd imagine a stock RCF exhaust would be pretty quiet. Probably no different to the IS250 system.
Or is it just for looks - quad pipes?
