hi all.
I'am looking for some help/guidance as I'am just back from my mechanic and we have diagnosed the rear diff as the cause of the rumbling/vibration felt when driving the car.
When the car was up on the lift and  spinning either wheel  while placing my hand on either wheel bearing I could feel nothing however when i placed my hand on the diff casing there was a definite vibration  from it .
we checked the fluid and it was nice and clean, so my questions are:
1. has anyone else expierenced this and what was the cure
2. is it a common issue ?
3. whats the best way to repair it ??
thanks in advance
Brendan
There is a TSB for vibration issues with the GS300h but this is an ECU update to stop the engine sitting at a specific rpm that causes resonance.
CP-0082L-0614
Models:
GS300h; IS300H
DESCRIPTION OF PHENOMENON
Some customers may experience and report vibration and droning noise when driving between 80 to 90km/h.
PRODUCTION CHANGE
1. Software logic of power management ECU has been changed.
2. Dynamic damper of Rear differential carrier has been added. (*)
* Applicable for ONLY IS300h
Cannot say whether your experience of the diff is normal or not.
hi colin ,
thanks for the info unfortunately  its definitely an issue internal to the diff itself 🫣 and will need to be replaced or fixed
regards
brendan
