I have a strange problem with my front sensors.
When I start driving the front sensors go beep. At about 8 mph it stops. When I reduce speed to below 8 mph they go off again.
Any thoughts ?
Sounds like a front sensor is permanently detecting an object. They only work when not in Park/Reverse and switch off at around 6 mph.
Give them a good clean, and also try getting any foreign objects out that are stuck within the circular gap around inner part of the sensor (use the edge of some paper for example).
