Hi all,
Hope you can help.
In my is200 there is a dab button, but it doesn't seem to work, am I missing something or was is an option when the car was first built.
How do I get this to work?
If it was an option from new, can this be retrofitted?
Cheers
Bob
I presume you mean IS220d rather than an IS200 from 1999-2004 so I've moved to the correct forum.
There was an optional module to enable DAB. Not sure if it is still available but an alternative option may be better. Here is a previous discussion on the subject:
Thanks Colin, and yes, it's the is200d 😊
Seems that there is an option to have this retrofitted, but it does seem expensive just to add dab.
Annoying that it wasn't added as standard.
