Hi I have fault code C1391 abnormal leak in accumulator on my 2010 RX450h. I am looking for an independant in the Wigan/North West area with Techstream capabilty. And so far am drawing a blank. I have ordered the OEM part from UAE for £600 as Lexus UK want £2,900. I have Techstream but when I tried to do the power bleed on the pump a while back I couldnt get it to do it. I would either like the part changed and the bleeding carried out and linear displacment set, or I fit it and have someone carry out the bleeding process. Hopefully someone has some pointers, as MOT is due next month and the warning light stays out for about 15 minutes, so liable to fail. Thanks.
