P1300 - Car Cutting off while driving and idling
my car started cutting off while driving and idling after cleaning the throttle body, When I scanned the car I got the code p1300, I check the coil no1 and it was working good, Can somebody help, the car seems to cutt off anytime it gets warm after about 10 minutes idling and driving
P1300 is the ignition on cylinder 1 but this could just be a false error if the idle speed is very low and the car is just randomly cutting out. What is the idle speed when warm?
You could try moving the coil pack to another cylinder to see if the fault moves with it or stays the same.
When Cold car idles a lil over 1400rpm,when warm it idles under 1200rpm but sometime when warm it idles under 1000rpm,
I move the coil pack to another cylinder and he car still cut of while idling
8 hours ago, ColinBarber said:
But has the error code changed or stayed the same?
code changed to coil pack no2, So tomorrow I will buy a coil and see if that works.
12 hours ago, steve2006 said:
I think given the above you may have found the problem 😀
Yes Problem fixed, Drove a couple miles today and it didn't stall at all
29 minutes ago, steve2006 said:
Good result, now firing on all 6 again, where are you located?
Yes Firing on all 6, I'm Located in Grenada.... prolly never heard of it but it's an island in the Caribbean
Been there on a cruise, bought spices from one of the stalls outside the cruise terminal and jewellery from Colombian Emeralds.
It wasn’t you I spoke to whilst driving your Altezza through the tunnel just up the road was it?
