Hi
i am the proud owner of the above car. I have a question: when the map is on the screen it seems to default to ‘north-up’. Is there a way I can reset it to default to ‘heads-up’?
Welcome Gary.
This may help:
If not the go please Menu  and go into settings > Navigation > Map > Map Layout and then select either the 2D or 3D heading-up option.
Thats the way it is !
Its bugged me big time since day 1 on mine.
No way to change it for the default/home screen.  When you go to the full nav display you can set it heads up fortunately.
