Good afternoon,
I recently purchased a Ct 200h that needs the front bumper replaced. The car's colour code is 223 (Graphite Black); however, I've found one online that is 212 (Obsidian Black). Would there be any noticeable difference if I put this on instead?
Cheers,
Ed
If you are buying a used bumper I would assume it's going to be scuffed / scratched so will probably need repainting anyway.
14 minutes ago, Las Palmas said:
Thank you both. It appears that the colours are distinct enough for me to consider getting it directly from Lexus.
I know they sell the part, but do they supply it painted to the car's respective colour code?
Looks like they are unpainted as they normally give the paint codes, plenty to chose from as well.
Your colour code has some pearl tinters in the pigmentation so puting a solid black bumper on your car is your own choice but you will notice in the sunlight and yes as stated it will have wear and tear marks. IMG_8229.thumb.png.915a8383a31ad159fd035812b9c9faad.pngIMG_8230.thumb.png.d5265d47f240a78598735dc0dbee89e5.png
Be careful with Obsidium as I’ve read that that colour code is different between the US and UK.
Any good repair shop should be able to paint to the correct colour code.
