Testing if AC condensation is leaking into footwell
I have wet carpet on passenger side and think it was a blocked moonroof drain that I think I have fixed. Carpet and padding are still very wet like there is an unlimited amount of water in there, makes me wonder if I haven't fixed it. I want to make sure it wasn't caused by blocked condensation pipe from AC. I ran the AC for 15 minutes today and didn't notice any condensation puddle under the car. It is 15C with low humidity here. I ran the climate system at 27C in auto with the AC on. Will that cause condensation in the system or do I need to run it at a lower temp ? What's best way to get max puddle ?
3 minutes ago, Spock66 said:
Lowest temp setting as this will make the A/C work the hardest.
Thanks ! I realized I'm in Eco mode, perhaps that is restricting condensation. I'll turn it off as well.
