So I need to top up my coolant on my LS460. It’s not leaking at all but need topping up. Am I best to drain it and refill it or just top it up with the recommended coolant.
Thinking.     When was the radiator last changed ?
10yrs / 100k miles might apply
It hasn’t been changed. It is on the to do list but for now I just want to top the coolant up. Problem is I don’t know what coolant is in it now so need to find out really.
well, if the radiator changeover is going to be prior to the onset of next winter then I would think maybe a simple top-up with distilled water might be ok  . you're not going to worry about it's deep cold / freeze preventative measures ........unless the changeover isn't really on that short horizon   🙃
