For some reason, whenever I start the car,  once the Bluetooth connection is established my music starts playing.
The phone is an Iphone and this never used to happen, it only started after I recently had to re pair the phone to the system. I've looked up any potential Iphone issues/solutions, but I'm not entirely sure it's down to the phone settings, as it doesn't autoplay when it connects to any other Bluetooth speakers.
Anyone have any idea how I can stop this happening?
1 hour ago, Bluemarlin said:
For some reason, whenever I start the car,  once the bluetooth connection is established my music starts playing.
The phone is an iPhone and this never used to happen, it only started after I recently had to re pair the phone to the system. I've looked up any potential iphone issues/solutions, but I'm not entirely sure it's down to the phone settings, as it doesn't autoplay when it connects to any other bluetooth speakers.
Yep! Same with my NX300h! You do not have to turn the music on the i-phone - the car does it automatically when you select Bluetooth. No idea how to turn it off. When I press the off button on the NX it automatically stops the i-phone playing. I thought it was a neat trick!
David, are  you saying that yours only starts when you select Bluetooth,  or when you start the car? I'd live with the former, but the latter is happening for me.
You have given me an idea though. Perhaps my audio is set to start in Bluetooth mode when I turn the car on, so I'll try fiddling with that and see if that's the cause.
You have given me an idea though. Perhaps my audio is set to start in bluetooth mode when I turn the car on, so I'll try fiddling with that and see if that's the cause.
Yes - when I select Bluetooth as the source, the MAIN i-phone connected is turned on and plays music automatically.  Just turning the car on does not start the music on the phone.
Hope this helps.
In a roundabout wayy I think it might have helped,  as I think my problem is that my audio is set to start on Bluetooth.   Will set it to radio and see if that stops it.
Thanks David.
If car was stopped with audio turned on it will start playing the latest source, Bluetooth, Disc, Radio.
Do not want this to happen. Turn off audio before stopping car.
