RX 400H
head lamps have moisture inside any advice ?
Can anyone point me in the right direction ?.
41 minutes ago, Sasbambam said:
RX 400H
One of my lights had this issue and I was advised to replace as it was not an easy job to reseal.
I got mine from a breakers - not cheap!
Why not just remove the bulb and blow warm air into the enclosure with a hair dryer.  This should clear the condensation at least temporarily.  If it recurs I would think that if you simply remove the headlight assembly it should be easy yo see if there is a leak in the seal between the glass and the reflector which could be sealed with a wipe of clear silicon bathroom sealer.  As you would have to remove the headlight to replace it not much lost by having a go.
Hear is another one from you tube using a hair dryer :-
You can always find a number of solutions to problems on you tube I use it all the time all the best John
