Hi
I am looking to set all 4 sensor heights to factory setting. Adjusting them looks easy enough. I'm guessing the car needs to be on a flat surface, suspension setting on normal height. Are there factory measurements from ground to wheel arch, or wheel centre to wheel arch, or something along those lines, to get the height correct?
Thanks in advance
Dave
I have the workshop manual for the 2002 model and it has the measurements. I don't know if it is the same measurements for a 2005 model. If it is, I can let you have them.
Sorry, forgot to say, this is for the 2003- 2006 models.
Andy
