Latest 04 Spec Is200
I'm currently driving an 04 plate SE. Its a courtesy car from Oxford. The steering is considerably lighter than my 51 plate Sport. Is this due to it being newer or being an SE? I prefer the heavier steering in mine, but that might just be because I'm used to it!
The suspension is also alot softer, but I assume that is due to the Sport having a different suspension set-up, i.e. 15mm lower etc.
Any thoughts?
I borrwed an 04 IS200 manual sprt for the day, this steering was light and responsive.
I then test drove an Altezza RS200 (210bhp 4 cyl), and found the steering heavey.
But the Altezza AS200 (153bhp) i settled on, has lighter sterring as per the uk spec.
Doesnt help, but that is my bit..................
Differing amounts of tread on tyres ??
They are not that different, the SE's will have been new in March and I replaced my fronts around the same time!
The SE does have different tyres, can't remember what they are, mine are Toyo T1-s's. Both 17". Shouldn't make such a noticeable difference as it is though.
