Rear parking sensors
My rear parking sensors appear to have stopoed working. Any one else had a similar fault, or is it possible my wife has accidentally found a button or setting to switch them off?
The fronts are working fine by the way.
This has been after a clean and fairly reasonable mild weather .... although frosty this morning.
I haven't used a high pressure hose while cleaning, as i believe that can cause issues .... so can't understand
On the RX I believe there is a menu setting where they can be disabled, so maybe something similar on the UX.
On other cars I have had you usually get an alert along the lines of "Clean Parking Sensors" rather than they just stop working.
