Changing roof rail retainer mould / chrome door trim
To be fair quite difficult to replace them because they seems to be glued together with window seals (if I imagine the part correctly).
Because I was able to polish them (meaning they are actually metal), then I assume they could be straightened with PDR. The cost will be similar to new peace, but won't require messing around with epoxy and on top of that just fitting it itself caul cause dents. I assume in factory they use some sort of purpose made jigs to fit it in one go and straight, doing it by hand would probably make it look worse then it already is.
