Hi friends
one of the switches on the headliner dashboard says "off" i presume this means the car alarm? If so, does it light or give some indication when on or off as it has no click to the switch
thanks
That switch turns off the anti intrusion sensors of the inside of the car.
If you press it to turn them off, a message will appear on the left side of the driver's display (the multifunction portion of the display).
Just try it, turn it off then turn it on again.
