I am getting no sound from my radio although it scans for stations and DVD player does not  work.
It is not a fuse problem.
Any help would be appreciated
Hi Michael. Has this just happened or did you buy the car with this fault? Does the unit actually light up when you turn the ignition on? If not then it maybe an idea to remove the unit to check its actually plugged on. You could check the amplifier which is in the boot on the right hand side under the floor trim. Check connections and if that area is flooded with water. Check for water damage if not flooded.
