NEW, to me 2018 CT200h Luxury
Al D-Much
Nothing really to add here but, they are a great little run around. Very low getting in and out though compared to my NX, not as young as I used to be. And, the foot/hand brake takes a little getting used to.
Just a couple of questions however.
1. Any way of turning off the safety camera beep?
2. It has the older rotary screen/nav system. Is split screen radio/map possible?
Split screen requires the 10" screen.
Do not remember. Went into setting - general and it was obvious what to do. Am not in car now and will look next time. If starting navigation having map on full screen (do not use navigation it is useless) and stop car and start again and the 3 split screen come as standard.
I think the icon in the very top right of the screen let's you configure the layout of the individual frames on the screen.  I can see it matches your current layout.
Paul
7 hours ago, Al D-Much said:
Couldn't find anything to achieve the split screen in my UK car.
Possibly different software depending on country?
Not impossible, but maybe which version of navigation system, audio system etc. is in the car.
Do you mean the beeping while in reverse? If so, yes you can turn this off using an OBD device like Carista.
Nope.
Safety camera / speeding camera alerts, not the park assist beeps.
45 minutes ago, Al D-Much said:
Nope.
Oh right, apologies, no I don't believe this can be turned off. I actually love this feature but I can understand how it could also be annoying.
The car beeps when seeing a speed radar, changing lane, trying to wake driver up (I write that as sometimes I do not know why it is beeping) and when Bluetooth is not connected correct with sufficient permissions.
Some of the beeps are OK and the rest I have to live with.
Only not correct thing with the CT is fuel consumption. Not that it is too much, but Lexus has stated close to half of what is actually used as consumption.
What fuel consumption are you getting?
I get between 56 and 58 miles per gallon, around 12 per litre
On the IS it turns off if you disable voice guidance in navigation. Maybe try and see if that works. You may need to turn the nav guidance volume all the way down. Shouldn't be a problem if you dont use the built in nav. Else no other way other than if you are savvy with techstream from what i understand.
Paul
Your Right Paul ..Click on that icon top right and you should be able to configure the layout of your Screen Try it And see if it works...Just might be the Answer..
