Coolant leak
lexus22
Checked coolant today, surprised that is needed 2 liters to bring up to top of radiator 🤔
Noticed that water is leaking from somewhere on the left of engine block, trouble is that it leaking from lower down, so can't get a view of exactly where it's leaking from, need to put up on a ramp but Santa never brought me one at Xmas 😠 is there a water hose or fitting down there that could be causing the leak?
So mechanic got a long mirror and a torch down there and diagnosed leak from thermostat housing, which is good news as reckon easy job to replace thermostat and o ring. Apart from the original Lexus coolant, is there another pink coolant that is okay to use?
So getting the thermostat housing off was not possible as one of the nuts cannot be removed due to there being some sort of silver cannister obstructing it 😠 . What the heck is this thing? Online videos do not show this cannister🤔🤔🤔
Hard to get a photo as it's situated below the thermostat housing, appears to be bolted to the engine, has quite a few pipes going through it, of different sizes🤔 strange that it's not seen on any online videos of is300, maybe it's a flux capacitor 🗓️
