Latest charge maintaining the level of recent results with a predicted 54.1/48.7 however actual is mid to high 30's.
Overnight charge indicating 54.1/48.1. Certainly appears to be levelling off within these figures.
  • Thanks 2
Overnight charge giving an almost exact repeat of yesterday's prediction at 54/48.1. Actual yesterday was a disappointing 32.
  • Thanks 2
The last two charges have been 53.9 with A/C on. Actuals are around 40 but that's running low speed short local trips.
  • Thanks 2
On 11/13/2023 at 8:12 PM, Alan Thompson said:
Tonight i'm showing 55.4/51.5.
Top down, bottom up - ooh er matron. 😁
Today I've got 55.4/50.9 and I noticed my miles p/kwh is now showing 2.9
  • Thanks 2
Overnight charge indicating a predicted 54.1/47.6. Miles per kWh now showing 2.7.  Overnight temperature c5 degrees.
  • Thanks 2
I achieved a range of 40miles against the above today.
Tonight's guess is 55.3/50.9
  • Thanks 2
That's pretty good Alan. My predicted 47.6 resulted in an actual 31 albeit the majority of the journey was motorway.
  • Thanks 2
Latest overnight charge and a big drop in prediction to 50.8/45.7. Winter is coming!
  • Thanks 2
To be fair Ken, I find that my 'actual' reduces the more miles I do, so if I'd have run the Battery all the way down I'd have probably also have been in the low 30's. The fact was I did 29 miles all on local roads and added the range that was showing as still available (11) to get to 40. I reckon those last 11 miles would have disappeared much quicker if I'd needed to continue a journey!
  • Like 4
8 hours ago, Alan Thompson said:
To be fair Ken, I find that my 'actual' reduces the more miles I do, so if I'd have run the battery all the way down I'd have probably also have been in the low 30's. The fact was I did 29 miles all on local roads and added the range that was showing as still available (11) to get to 40. I reckon those last 11 miles would have disappeared much quicker if I'd needed to continue a journey!
And to prove it, last night's guess of 50.9 resulted in an actual 34 - I arrived home with the range just clicking over to 0 !!!
There was two M1 trips of 8 miles each way and a couple of other short 'blasts' on dual carriageways, so different driving today but it's been 15 degrees F in Leeds today, so I've had my knotted hankie on my head and trousers rolled up to my knees. 😃
  • Haha 3
Yes. The first 50% of the Battery lasts far better than the second half!
On my new Lexus app it shows ev range 49.8, with a/c 47.3
Fuel range 156
Total range with a/c 144.2.
It cannot count !?
Fuel range 156
It cannot count !?
I have the same issue
Tonight's guess is 55.2/51.4 which is increasing slightly.
I actually drove 31 miles today with a range showing as 10 miles left.
  • Thanks 2
Overnight charge showing a marginal increase on previous with a predicted 51/45.9.
Actual from the previous 45.7 was mid 30's.
  • Thanks 2
Fuel range 156
It cannot count !?
Exactly the same here. Have more or less given up on the +app....as I suspect others have too.
So disappointing  as 'the old app' worked much better with no issues.
This morning I've charged from 0 range to full having driven 39 miles on Battery yesterday.
Today's guess is 55.2/50.8
  • Thanks 2
Still seeing 54 with a/c and about 3.1 m/kwh
Overnight charge indicating a predicted 51.1/45.5. Last actual was 35 against a predicted 45.9.
  • Thanks 2
My last 3 have been 45.2/43.4 (15 Nov), 45.5/43.7 (16 Nov) and 45.7/43.0 (23 Nov). Very similar to predictions throughout the whole of November, (45.5/43.2 on 1st Nov). Has to be seen in the context that I was getting 50+ in September (50.3/49.3 on 29 Sep) before the predictions unexplainably fell off a cliff after a long trip to Wales in October.
I don't know what my actual distances are because I rarely travel all electric until it runs out; preferring to swap into HV mode for steady speed 'A' roads, dropping into EV mode for towns, and aiming to arrive home with as close to zero range left as I can manage.
On 11/22/2023 at 1:32 PM, Alan Thompson said:
This morning I've charged from 0 range to full having driven 39 miles on battery yesterday.
Tonight's estimate is 55.2/51.4
