Other Makes
What Car March 23 ran an interesting comparison article on the range difference between summer and winter for BEVs. Two things jumped out to me:
Actual range achieved in July last year and this January was an average of 18% lower for the 3 vehicles on test due to the colder weather.
There was a big difference between the claimed official range and the actual range achieved in January. This varied from a shortfall of 16.4% (Nissan Ariya) to 32.8% (Ora Funky Cat - yes that's a real car!).
I'm convinced that good design and solid engineering makes a big difference to real world results and hence the enjoyment and satisfaction one gets from their vehicle.
Tonight's figures are 50.6/48.1. That's the best with aircon total so far this year.
Slightly better with aircon figures tonight of 50/48.4.
Last night's 48.1 range gave an actual of 40 miles today which included over 20 miles of motorway travel.
Improving situation again. Tonight's figures 51.1/48.6.
Almost identical result from tonight's charge of 51.2/48.6
Getting better- 51.3/48.8 showing from the latest charge.
  • Thanks 2
On 4/7/2023 at 7:42 PM, Alan Thompson said:
51.8/49.2 tonight
From the 49.2 estimate I got 42 miles this included about 12 miles on motorways.
Tonight's charge 51.3/49.3 which is the best with air con indicated range so far this year.
  • Thanks 2
Pardon me for being a bit thick but how does the car work out this estimation?
Tonight's recharge 51.4/49.4. Marginally better than last charge.
I’ve been away for a few weeks (7 in fact)
On return car was ok. I left it with 85% on EV Battery and it was same on return.
Put it on charge this afternoon since sun was shining on my PV panels.
Fully charged and I’m now showing 43.4/40.3
That's mighty impressive. 41.5/38.8 here with car saying an average of 2.8kw/m.
Is there somewhere either on the app or in the car you can see exactly how much Kw you have put in for your last charge?
Nothing on the car or app that I am aware of.
I have and use a 7.5 kw OHME home charger. The app shows quite a number of stats including how much Kw per charge at any one time and cost per charge based on my current providers tariff.
On most charges the car needs approx 15 Kw from zero [zero figure including the 30% already show on the display]] to 100%.
So if you multiply your current energy provider Kw/Hr tariff by 15 [assuming empty battery] then that will give you a approx cost per charge.
Hope this is of some help.
I have a Hive home charger and the KwH input is recorded on the Hive app. Also shows the cost based upon the current tariff.
I have an Easee 7kw charger which is linked to the Hive app but also has its own app. Both apps show the amount of KWh added each charge and the cost based upon my tariff. This can be seen for either each charge, month to date, month etc
Tonight's charge 51.5/48.9. Non aircon figure slightly higher but with aircon slightly lower.
Tonight's recharge giving the best result of the year so far - 51.8/49.7
