Anyone else noticed this ?
Some slight condensation forming in my headlights:(
A bit disappointing to be honest as I knew this can be a sign of a failure of the HID headlight in the future with moisture ingress
Fogging or slight condensation in the headlamps is fairly common and as long as it dissipates after the lights have been on a while it shouldn't be a problem.
If it's quite heavy condensation or you are particularly worried check the back of the headlamps and make sure the access ports are properly closed.
I had to replace my headlight despite taking it out and drying it.  I never found the source, so ended up replacing it with a new one.
