I know this will have been done many times, but what are you guys recommending for discs and pads for 2007 IS250
        Cheers,
        Alan
Genuine. Should be about £195 for the full front set. EBC are a smidge cheaper but for the difference you might as well fit genuine.
        Cheers,
        Alan
Hi Alan,
If you use your car for regular driving (no racing or anything), I'd suggest any OE products. It's the same product at the end of the day, especially as far as discs go, with pads I'd go for some more known brands. There is absolutely no point spending premium on OEM (genuine "Lexus") parts.
Front Discs from Ferodo (very good aftermarket brake manufacturer) - £84 for both - https://www.autodoc.co.uk/ferodo/11012031
Front pads from Ferodo to go with the discs > £49 - https://www.autodoc.co.uk/ferodo/1508204
You can find cheaper alternatives to both, but I'd personally go with these..good proven brand and doesn't cost an arm.
5 hours ago, H3XME said:
Hi Alan,
Hiya Lucas,
                   my thoughts exactly. brembo at £45 or as you say plenty other well known brands.
        Cheers mate .
