Fun Stuff
tdiplc
Wife 1.0
Last year I upgraded Girlfriend 1.0 to Wife 1.0 and noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this phenomenon was included in the product brochure. In addition, Wife 1.0 installs itself into all other programs and launches during system initialization where it monitors all other system activity. Applications such as Pokernight 10.3 and Beerbash 2.5 no longer run, crashing the system whenever selected. I cannot seem to purge Wife1.0 from my system. I am thinking about going back to Girlfriend 1.0 but un-install does not work on this program. Can you help me? * Jonathan Powell
Dear Jonathan Powell- This is a very common complaint but is mostly due to a primary misconception. Many people upgrade from girlfriend 1.0 to Wife 1.0 with the idea that Wife 1.0 is merely a "UTILITIES & ENTERTAINMENT" program. Wife 1.0 is an OPERATING SYSTEM and designed by its creator to run everything. WARNING DO NOT TRY TO: un-install, delete, or purge the program from the system once installed. Trying to un-install Wife1.0 can be disastrous. Doing so may destroy your hard and/or floppy drive. Trying to un-install or remove Wife 1.0 will destroy valuable system resources. You cannot go back to Girlfriend 1.0 because Wife 1.0 is not designed to do this.
Some have tried to install Girlfriend 2.0 or Wife 2.0 but end up with more problems than the original system. Look in your manual under Warnings-Alimony/Child Support. Others have tried to run Girlfriend 1.0 in the background, while Wife 1.0 is running. Eventually, Wife 1.0 detects Girlfriend 1.0 and a system conflict occurs, this can lead to a non-recoverable system crash. Some users have tried to download similar products such as Fling and 1NiteStand. Often their systems have become infected with a virus.
I recommend you keep Wife 1.0 and just deal with the situation. Having Wife 1.0 installed myself, I might also suggest you read the entire section regarding General Protection Faults (GPFs). You must assume all responsibility for faults and problems that might occur. The best course of action will be to push apologize button then reset button as soon as lockup occurs. System will run smooth as long as you take the blame for all GPFs. Wife 1.0 is a great program but is very high maintenance.
Suggestions for improved operation of Wife 1.0
* Monthly use utilities such as TLC and FTD * Frequently use Communicator 5.0
Tech Support
HAZARDOUS MATERIALS INFORMATION SHEET
MATERIALS SAFETY DATA SHEET
WOMEN - A CHEMICAL ANALYSIS
ELEMENT: Women
SYMBOL: Wo
DISCOVERER: Adam
ATOMIC MASS: Accepted at 53.6kg, but known to vary from 40-200kg
OCCURRENCES: Copious quantities in all urban areas
PHYSICAL PROPERTIES:
1. Surface usually covered in painted film.
2. Boils at nothing; freezes without known reason.
3. Melts if given special treatment.
4. Bitter if incorrectly used.
5. Found in various states from virgin metal to common ore.
6. Yields if pressure applied in correct places.
CHEMICAL PROPERTIES:
1. Has great affinity for gold, silver, and a range of precious stones.
2. Absorbs great quantities of expensive substances.
3. May explode spontaneously without prior warning and for no known reason.
4. Insoluble in liquids, but activity increases greatly by saturation in alcohol.
5. Most powerful money reducing agent known to man.
COMMON USES:
1. Highly ornamental, especially in sports cars.
2. Can be a great aid to relaxation .
3. Very effective cleaning agent.
TESTS:
1. Pure specimen turns rosy pink when discovered in the natural state.
2. Turns green when placed beside a better specimen.
HAZARDS:
1. Highly dangerous except in experienced hands.
2. Illegal to possess more than one, although several can be maintained
at different locations as long as specimens do not come into direct
contact with each other.
