Altezza Datalog
OLI_EP3
Well I came across this list from NZLOC and thought it may be useful here
Thank PIK for this.........
Also, is it possible to make this 'sticky' for other Tezza owners to benefit pls Mods? :)
Engine oil
3S-GE oil change only=4.8 Liters/ recomended grade 5W30/SJ
3S-GE oil change with filter=5.1Liters/recomended grade 5W30/SJ
1G-FE oil change only=3.9 Liters recomended grade 10W30/SJ
1G-FE oil change with filter=4.1 L iters recommended grade 10W30/SH
Transmission oil
Toyota genuine MG gear oil special II (API GL-3 and SAE75W-90)
6 speeds MT 1.95 L 70W90/GL3
5 speeds AT 7.2 L Type T-IV
4th gear AT 6.3 L Type T-IV
Diff. oil
The Toyota genuine high boiled gear oil SX (API GL-5 and SAE85W-90)
LSD 1.00 L 85W90/GL5
NO LSD 1.05 L 85W90/GL5
Brake fluid --- Genuine 2500H
Clutch fluid --- Genuine 2500H
Power steering fluid 0.9 L
Coolant
3S-GE 6.8 L
1G-FE 6.6 L
Wheel alignment reference setting (SXE10 and GXE10)
Front side slip 0±5
Front camber -0°30'±45'
Front caster 6°05'±45'
Front king pin angle 9°25'±45'
Front toe in 1±2mm
Rear camber -0°55'±45'
Rear toe in 2±2mm
is200
FRONT
Caster Min = 5 deg 16', Max = 6 deg 16'
Camber Min = -0 deg 51', Max = 0 deg 9'
Toe Min = -0 deg 6', Max = 0 deg 18'
SAI = 9 deg 16'
REAR
Camber Min = -0 deg 53', Max = 0 deg 7'
Toe Min = 0 deg, Max = 0 deg 24'
Battery size
Standard=34B19L
Electro upgrade- HID Lights/heated seats=46B24L
Cold area specification and the TRC equipment/AS200=55D23L
Part # of general service items
Front disk 43512-22220
Rear disk 42431-51010
F disk pad 04465-30080
R disk pad 04466-51010
Filter element 1G-FE (GXE10) 17801-70050
Oil filter 1G-FE (GXE10) 90915-20001
Filter element 3S-GE (SXE10)17801-46080
Oil filter 3S-GE (SXE10) 90915-10001
Clutch cover ASSY 31210-22150 SXE10 (M/T)
Clutch disk ASSY 31250-53011 SXE10 (M/T)
Clutch bearing 31230-53010 SXE10 (M/T)
Input shaft bearing 90363-12004 SXE10 (M/T)
bulbs
Headlight Low 12V51W-HB4
Headlight Hi 12V60W-HB3
Fog lamp 12V51W-HB4
Small lamp 12V5W- wedge sphere
Wien car (front side) 12V21W- wedge sphere
Wien car (front fender) 12V5W- wedge sphere
Wien car (rear side) 12V21W- invar valve
Rear small & stop (inside) 12V21/5W- wedge sphere
Rear small & stop (outside) 12V21/5W- wedge sphere
Back lamp 12V21W- wedge sphere
Rear fog lamp 12V21W- wedge sphere
License number light 12V5W- wedge sphere
High mount stop lamp 12V18W- wedge sphere
Map lamp 12V10W/12V8W- wedge sphere
Room lamp 12V8W- wedge sphere
Grab box lamp 12V1.2W
Front ashtray 12V1.4W
Ignition key hole illumination 12V1.4W
Plugs
Stock factory plug: NGK- BKR6EP (platinum)
Others used :NGK/IRIDIUM IX- BKR6EIX-11
DENSO/IRIDIUM TOUGH VK20
(Item number: V9110-5604)
DENSO/IRIDIUM POWER IK22
(Item turn: V9110-5310)
DENSO/IRIDIUM POWER IK20
(Item turn: 067700-8690)
TRD/ iridium sparkplug NGK7 turn suitable
(Item turn: 19059-SP004-22)
(DENSO PK20R11)
(If any of this is wrong or country specific please edit it pls!?)
Very useful info mate, however, in the manual it states 5w-30 oil for the 3S-GE engine in colder climates and 10W-30 for warmer climates,( Warmer including us believe it or not...lol)
Also, I think the NGK iridium plugs are standard and not the Platinum ones...
Top info though matie, and i`m sure lots of folk will find it interesting and VERY useful.... :D
  • 1 year later...
Also, I think the NGK Iridium plugs are standard and not the Platinum ones...
Do you have the electronic version of this manual scott?
