Non Loc Forum Error
Rob
hi all i keep having probs with a forum i use and every now and then i keep getting errors such as the one below - is it my end or thiers ( im thinking thiers) and what exactly does the error mean.
** Error message has been edited at points***
Warning: mysql_connect(): Too many connections in ( web address removed) on line 67
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in ( web address removed) on line 70
ERROR: Cannot find database *******-********
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in ( web address removed) on line 103
There appears to be an error with the ******* database.
You can try to refresh the page by clicking here, if this does not fix the error, you can contact the board administrator by clicking here
Error Returned
mySQL query error: SELECT id, member_id, running_time, location FROM ibf_sessions WHERE id= ******************* and ip_address='81.***.******
mySQL error: Too many connections
mySQL error code:
Date: Monday 26th of April 2004 07:27:14 AM
