Hi.
I noticed today that on a flat surface the near side rear gap between wheel and arch is much less than off side rear wheel and arch.
Is it a bad spring ? Will it fail mot? Thanks
Will I need to replace both sides or one side will do? And should I replace shock absorber, end link or anything else?
What brand of parts do you recommend and where to get them from ?
Get two, springs get tired over time, if you have one brand new and one old, it won't be level. If the shocks don't leak, no need to change anything else. Go for this: https://www.autodoc.co.uk/japko/16243040 you can order just 1 if you really want to, but I'd swap both for the reason above.
Could be a broken spring. Turn the steering wheel to the affected side and see if you spot anything.
You dont need to change anything else.
Some springs dont require changing both sides. I know Mercedes springs they only change one side
At that price it's a no brainer. Plus metal fatigues over time. Safety is paramount therefore both sides should be changed.
Take your car to a garage with a lift. Ask them to check and then go from there. Not all tarmac surfaces are flat. Lifts are.
