Memory function for driver
I moved the seat to its furthest forward position, followed by its furthest rearward position, then put the reclining backrest to its most upright position and finally to its most reclined position. I then sat in the seat and adjusted everything to its final position that suited me and "recorded" this by holding set with button 1. You can then repeat to hold configurations for other drivers at buttons 2 and 3. Details are in the handbook. Hope this helps!
35 minutes ago, FSPORT3 said:
Would someone be able to clarify how to store a driving position using the memory function - I can set a steering wheel position but not the seat?
Once seat set and steering wheel set to your requirements look to setting buttons on drivers door. press set button and 1 at same time and memory is set.
also if you go into settings you can programme setting to specific key so car knows who driving.  Seat and wheel will move to desired position automatically and on arrival at destination and unfastening seat belt will both retract.
Does the key specific function is available for all trim with electric seats?
I had the same issue with the seat position not sticking and it just needed a reset, as per Ken's helpful instructions.
Thank you, I tried this and have now been able to save seat settings.
