I wonder if anyone could advise how to replace the indicater repeater lamp assy, side (part L81730-78010) on my NX300h. It's the one under the mirror. I missed this not working when preparing for MOT (fail). I've ordered the replacement (£103.52 !!) and have a week to fit before re-test. Any help appreciated.
Thanks Colin. It does look a bit complex & prone to damaging the plastic on a first attempt. I'll give it a go and hope reassembly will be a little easier. Regards, Ian
Managed to replace the side repeater without a hitch, working slowly with plastic trim tools I already had. Re-attaching the upper cover took the longest time. More of a sliding into position from the bottom and then pressing rather than a straight on push. Gave me a satisfying sense of achievement and saved me almost £50 from lexus! Many thanks to the valuable input from Colin & Peter.
Congratulations Ian, satisfying to read as well as your own sense of satisfaction, and an encouragement to have a go at jobs that at first seem impossible - until you get the info from Colin and others 🙂 Embodies all that is good about these forums.
