Hi John,
I just checked on my car and I also have the same plug and just like yours it is not connected to anything so I don't imagine it is anything to be concerned about.
The connection for the temperature sensor would be on the other side of the Battery and may or may not have the sensor attached to it. The sensor would normally be clipped to the Battery enclosure which is missing from your car. You can see it attached to the enclosure in the photo you posted. The seperate plate shown in the photo sits below the Battery and should probably still be present in your car though you would probably have to remove the Battery to confirm.
Hope this helps.
Dec.
15 hours ago, Beamish said:
Hi John,
The connection for the temperature sensor would be on the other side of the battery and may or may not have the sensor attached to it. The sensor would normally be clipped to the battery enclosure which is missing from your car. You can see it attached to the enclosure in the photo you posted. The seperate plate shown in the photo sits below the battery and should probably still be present in your car though you would probably have to remove the battery to confirm.
Hope this helps.
Dec.
Hey,this makes a lot of sense.
On 12/26/2022 at 2:02 PM, true blue said:
Hi my car does not have a battery cover as such ,it has an open frame all round which is held by the clamps in your drawing .The inner facing side of the case has a wired sender attached to the side which I believe is to monitor the battery if overheating occurs ,this can be awkward when replacing the battery so perhaps it has been left off when this was done.If your battery is not a Panasonic it has probably been replaced .The terminals have their own cover
Dave
So been digging around and now found this cable
on the left side ?
That looks familiar. It slides up, let's call it a, a channel on the Battery housing case call it what you will on the +ve side. Like I said previously it's best to have Battery out so you can manipulate the casing.
  • Confused 1
16 minutes ago, Mr Vlad said:
That looks familiar. It slides up, let's call it a, a channel on the battery housing case call it what you will on the +ve side. Like I said previously it's best to have battery out so you can manipulate the casing.
I don’t have the plastic casing does it go underneath the tray at the bottom
That is the temperature sensor which you are holding between your fingers.
If you simply tape it to the side of the Battery towards the top it should function as normal.
Ok thanks great idea,  I will try this with some gaffer tape. Also I will definitely disconnect it to reboot hopefully it still works
30 minutes ago, Mr Vlad said:
As Declan said.
I have disconnected it and taped it to the side of the Battery ?? All ok ??
not sure ?
If you simply tape it to the side of the battery towards the top it should function as normal.
I’ve done it
