Hi guys,
I own a 2019 RC300h F-Sport Executive . And almost from the beginning I experience quite ennoying strong vibrations even at idle while car is stopped. But vibrations get stronger when I drive. I mentionned it the the dealer twice with no success. He concluded that it was related to the tyres, but he was wrong (it would not explain why the car is vibrating when stopped)
I fear that this vibration may be caused by the CVT transmission.
Has anyone experienced the same problem?
Thanks for your comments.
Exhaust pipe hanger, perhaps.  If damaged, any vibration would tend to worsen when you drive.  Did your dealer lift the car to check underneath?
Just noticed from an earlier post of yours that your RC has non-standard exhausts.  Are you sure they were properly installed?
  • 2 months later...
